I have an 80 z28 and I can not get any power with the key in the accessory position. Is this caused by the ignition switch only or is there some other cause?
If everything that would get power in the ACC position is working in the ON position then I would have to say the problem is the ignition switch.
'69 RS Camaro
355 5-speed 4.11
Yes everything works in the on position. Ok I'll replace the switch.
