I am looking to adapt my transmission hard line to an AN fitting without cutting the line and having to use a compression fitting to AN adapter (or removing the hard lines completely and using all braided).
Do they make adapters from a female inverted flare to AN that would fit transmission hard lines? I know a few companies make similar adapters for brake hard lines, but I haven't seen other sizes.
I'm doing this so I can use AN fittings on a transmission cooler and not have to run rubber hoses to the cooler, instead using braided line.
Thanks guys for any help.
Mike
check these guys out, http://www.godmanhiperformance.com I was reffered to them by a tech at Edelbrock for a custom fuel injection setup im designing. they have sevral types of fittings I havent seen elsewhere, and some that appear that they adapt trans cooler ports to the AN style fittings your talking about. hope this helps you out.
:thumbsup:
