What is required to convert to a power brake booster.. What part will crossover to a 68 camaro?.. Is the conversion straight forward?.. Does the power brake booster come with the pedal rod or will I need to fabricate something since im not sure the stock one will work.. Right now I have drums in the rear and 4 piston disk in the front... Any info would be appreciated
Thank you
Give Matt's Classic Bowties a call and they can set you up. Don't know about the proportioning valve and master cylinder....you may need new ones. The booster comes with a rod and you can reuse your clevis but you mount it lower on the brake pedal arm.
The kits from Matt's (Right Stuff) use a combo unit so the distribution block and proportioning valve are one unit. I went rear disc as well with their combo unit so the little block on the frame got adiosed.....don't know what they require you do with that if you run disc/drum.
