Man, the term shade tree mechanic comes to mindA two ton lift is what you need. Your wife will appreciate your new tool. It is good for pulling out old trees and bushes in the yard. I use my truck for the front yard.
Great minds think alike.LOL I did fence posts as well.
I'm thinking that's the route to go. Either buy it and sell the 1-ton or I rent a 2 ton as needed and keep the 1-ton for moving engines around separately. Leaning toward buying the 2 ton just for the convenience of having it handy.Get the Harbor freight 2 ton. I have only pulled the engine with out the transmission once and to many times with always small block muncie combo. I have an extra yoke to stick in the back of the transmission you can put a plastic bag around for added security. As mentioned above hood off, rad out, accessories off. Carb plate works good have done it with chains as well, prefer carb plate.
Thank youHarbor Freight 2 ton reaches fine. Princess Auto too short Canadian. I have always pulled together as mentioned. It is 6 of one half dozen of the other. If you do not remove transmission make sure it is supported.
She was pissed when I told her I needed another one. LOL. Let's just say I have a lot of things and it irritates her to no end.A two ton lift is what you need. Your wife will appreciate your new tool. It is good for pulling out old trees and bushes in the yard. I use my truck for the front yard.
Nice!LOL I did fence posts as well.
Thanks. I wish I had looked more into it before buying the first one. At least I used it a couple times and can sell it and get some money back.Yes you need a 2 ton hoist to pull a V8 engine and transmission. Those HF 1-ton units are for 4 cylinder engines.
I work in construction and we call that a carpenter's bandage. Different trades call them similar names. Always doing tailgate triage out on jobs.All good advice.
And if you slice a finger open, forget a Band-Aid. Grab a paper towel/rag and the electrical tape and just wrap it up. Last a lot longer and easily replaced.
Thank you, good advice.Have always pulled both as a unit mostly by myself except for the hood. You need the two ton. never used a leveler, just chains but leveler would have been easier that ratcheting the chain over the hook. Never crushed any body parts, mine or the car. But that was long ago, This many years later might look at it differently. pain is easier to get and harder to recover from.
Yep, back in the day I did mine with the transmission together too, AND I removed the hood by myself too - never scratched the paint either. Pretty easy with a manual steering + no AC SBC. Took me about 45 minutes to do get it out.Have always pulled both as a unit mostly by myself except for the hood. You need the two ton. never used a leveler, just chains but leveler would have been easier that ratcheting the chain over the hook. Never crushed any body parts, mine or the car. But that was long ago, This many years later might look at it differently. pain is easier to get and harder to recover from.
Not that I’m an expert but I’ve been working on cars for over 60 years! To answer your question, yes you need at least a 2 ton engine hoist with the longer extension arms , yes, remove your hood first to make things much easier , remove the driveshaft and yes leave your transmission attached to give weight in the rear. You want the engine to come up and out at about a 45 degree angle. Do so very carefully and have a couple of friends helping you to watch for clearances. Hope this helps you! No need to remove anything but the hood !I've never pulled an engine before and need some advice before I jump right into it. I'll describe the situation first and then have some questions at the end. Any input is appreciated. Back about the mid 80's the original 302 was pulled and the heads and other parts were taken off and installed on a 327, which is in the car now. I want to take the 327 out, take off all the original 302 parts, and send them and the 302 to the machine shop. The m21 needs some work so now is a good time to pull it as well. I bought a 1 ton folding engine hoist from harbor freight assuming it would work, as well as a engine leveler, and tried to do a "dry run" to make sure it set into place. I had to jack the front of the car up slightly to fit the hoist underneath, but the hoist is too far forward of the center of the engine, just over a foot away, and can't go in any further because it is right up against the bumper. Also the hood is in the way.
1. It appears I need to remove the hood to pull the engine. Is that correct?
2. I need to push the engine hoist closer toward the engine another 16 inches (roughly) and it appears I could gain about that much if I removed the bumper, grille, header panel, etc up until the radiator support. Is that something that is normally done or would that be a big mistake to do? Or did I buy too small of a engine hoist and need a larger one? If so, would the 2 ton from harbor freight work? I might be able to buy a longer piece of square tube and modify the hoist arm to reach deeper into the engine bay, but that seems sketchy.
3. Should I leave the transmission bolted to the engine when I pull it? Someone told me it's a lot easier to install an engine and transmission (especially manual) together, is this true?
I have other questions but they're more about the reinstall process so I'll ask those separately. If anyone has any general advice for pulling an engine I'd be appreciative since it's my first time and the guys helping me don't have a lot of experience either.
Thank you.
If in a garage, look into attic to see if you can add some beef up on celling joists to use them to pull engine. Then go get a block and tackle , or -come-a-long ratchet system or a boat winch with steel cable to lift the engine out. I have used all three in my 45 years of pulling engines. Just need to add pulleys and any support to do it safely and easily.
Or get a larger hoist which has the needed depth from cylinder you need to pull engine. I think I got the 3 ton HF hoist 11 years ago and it has worked for me, so far, but I haven't pulled a Camaro engine with it.
Either way, you will need to change something to engine out, then back in. I would attempt modifying a 1 ton hoist to work as any mod will reduce it lifting capability. You are already at 1/4 ton (500 lbs) lift point that would be considered a barely safe minimum to pull the engine & transmission.
Don't cheap on this tool for your garage. It can create more damage than you want, if it fails.
I know my dad used to pull them in the garage. There was a I believe it was a 4X6 beam and what he did was put two 4X4’s under the beam on each side of the car then he had the hoist with the long chains that you pull one for up one for down and put that in the center of the beam. He pulled the car in hooked it up and lifted it and pushed the car back out of the way. He sure made it look simple. I’m not sure the name of those pulleys but it worked great just another option. Good luck to youI've never pulled an engine before and need some advice before I jump right into it. I'll describe the situation first and then have some questions at the end. Any input is appreciated. Back about the mid 80's the original 302 was pulled and the heads and other parts were taken off and installed on a 327, which is in the car now. I want to take the 327 out, take off all the original 302 parts, and send them and the 302 to the machine shop. The m21 needs some work so now is a good time to pull it as well. I bought a 1 ton folding engine hoist from harbor freight assuming it would work, as well as a engine leveler, and tried to do a "dry run" to make sure it set into place. I had to jack the front of the car up slightly to fit the hoist underneath, but the hoist is too far forward of the center of the engine, just over a foot away, and can't go in any further because it is right up against the bumper. Also the hood is in the way.
Thank you.
