1 - 2 of 2 Posts
OK,
So I have a 327, double hump heads, unknown cam, HEI, dual plane Edelbrock, 350TH, Holley Street Avenger 570. I have been working with an Innovate LM2, and tuning on this carb for some time:
I have swapped out the primary metering block for a Proform with adjustable IFR & PVCR
I have removed the fixed air bleeds, and tapped them for adjustables, but have not changed any stock settings.
59 Primaries
64 Secondaries
31 PVCR
Idle is a bit rich at high 12's, but the Primaries are right on giving a higher rpm cruise of 14.7, and when the PV kicks in it goes to about 12.8.
There is a rich bog off the line, with or without secondaries. My question looking at the comparison graph of primaries to no primaries, what is causing the rich hole in the first 4 seconds of an off the line run?
Well I am not a tuning genius but that actually seems ok. I would open up the idle air bleed to lean out the idle circuit unless you can just turn the screws in a touch.The rich hole could be from the power valve opening too soon. It could also be from the timing not advancing fast enough. Please this is just an educated guess I am not a mechanic, just trying to throw possible ideas to you.
1 - 2 of 2 Posts
