I am going to run an autometer fuel level gauge, can I use the stock sender and how many ohms should the gauge be rated at for the stock sender? The car is 1968, I would appreciate any input.
What does the guage say it needs?
Autometer makes gauges to work off of various senders from Ford, GM, Chrysler, etc...
Usually, the GM standard is a 0-90 ohm sending unit with corresponding gauge.
David
George is correct, I am using an Auto-Meter fuel gauge with the factory in-tank sending unit and it works mint... Good luck!
1969 Camaro SS 350-383ci., T-56, 12 bolt, Eaton posi, 3.31 gears, 4 wheel disc, Deluxe black houndstooth interior, rear window defogger, tilt steering, console w/AutoMeter gauge package, center mntd. clock, Tach.
Thanks guys, the plan is to use an autometer guage within a console cluster. 90 ohms it is.
