Aftermarket one inch rear sway bar removed from a 67.
One hole drilled through each frame rail to mount the upper bracket for the links.
Bar bolted to the bottom spring plates using the existing U bolts.
Any idea who made it?
I SUSPECT, but don't know for certain, that the two ears welded on the bar just inside each lower link were added
