can somone please tell me whats happin? Start car up go for a short drive, shut car off and the car keeps running... it doesnt shut off keeps putting for like 30 or 40 seconds.whats up with that can somoe help??
Is the car fully running?
Or is it kinda like put put put put sounding.
If it is the latter, it is "dieseling"
It is from gas entering the cylinders and the pistons compressing the gas and the heat ignites it.
If you increase your fuel octane a couple points it should stop it, or adjusting your fuel system and ignition systems and giving the car a tune up.
are you running an MSD ignition? When I first installed my MSD, I had the same problem.
Discussion Starter · #5 ·
it's a bone stock 350 think it could be getting too much fuel?maybe the carb is messed up. also when i take it on long trips it doesnt do it only on short trips..if you shut the car off in drive it doesnt do it as much
Check the timing, see if its too advanced, Be sure you're idle speed is not too high, Make sure you're not running it hot. These can cause it. As Joshua Leslie said, upping the octane may help.
