I am about to start assembly on my stock 69 subframe steering components and after reading posts from here and on other forums I am not sure of my setup.
Per many of David Pozzi's posts and his website, he recommends running a constant ratio box (12.7:1) with a short pitman and short steering arms, but I also see in his website he provided information for a factory variable ratio combo in a 69 Camaro that seems to be close to my setup: N40 N44 16:1 - 12.4-114.3:1 - 10.8:1 Turns - 2.2, Long Pitman and Short Arms.
I have a AGR variable ratio box, Long Pitman, Long Idler, Short arms. I am curious to know what I should expect from my setup. David mentions the fast of everything is too fast with a 12.7:1 box, but I am curious to know does that apply to a variable box as well? Should I stop and change my steering components?
I have the AGR 292317 Billet Box (13-16:1). I called AGR and they told me the box will be 3.3 lock to lock in the car, but I do not know what arms/pitman/etc they used as reference.
My Parts list:
Pitman, PS Long K6154 (5.78") (Old Stock)
Idler arm Long (5.8") #20227 (Rare Parts 67 Replacement)
Large center link is (1.125") GM#3953221
Steering Arms Short (5.25") LH-3954875 RH-3954876
Adding to this: My other suspension components:
DSE Upper and Lower Control Arms
JRi Coil overs
ATS Tall Spindles
Bear Tracker outer tie rods
Thank you,
Jorge
My Parts list:
JRi Coil overs
ATS Tall Spindles
Thank you,
Jorge
