2001 Camaro SS - had the engine out for repair, got it all back together. Everything is working great except my airbag light won't go off. Would could it be and what should I do to fix it? Do I need a pro/dealer?
You need a scan tool to read the code to find out why its on!! Could be just a fault code from having the engine out or maybe you broke a connecter or maybe you have a legit problem!!
Looks like I broke the clockspring inside the steering wheel while it was disconnected from the Rack. If you turn the wheel to far it snaps the clockspring which connects the airbag and the steering wheel controls (which are also not working). This part is $165 plus $30 shipping from GMpartsdirect.com. Yikes.. expensive way to learn to keep the wheel locked while not connected to the rack/pinion.
Lesson learned im sure!! But now you will know for next time!!
