I am looking for an after market air breather for my stock gm valve covers that will keep them looking stock (no chrome). The hole opening is only about 3/4" and I know that I can hook up two PCV valves but would perfer not to.
Summit Racing and Jegs also have the breathers in many different types.
head to any parts store and browse thru their cheap chrome section. i almost always see a breather for the small hole.
while you're there, pick up some of the "feet" things that go over your pedals..
I'll try linking you like I linked Jim...
http://paceperformance.com/index.asp?PageAction=PRODSEARCH&txtSearch=breather
Your only real choice for a breather that isn't chrome is to get a chrome one and paint it. Because the stock breather is actaully a tube hooked to the base or side of the air cleaner housing, there isn't a separate breater that is "stock". They are all after market, and all the ones I have ever seen are chromed.
novaderrik is right too; most any Pep Boys, Advance Auto, etc., carries the breathers for the smaller hole.
Has anyone else ever used 2 pcv valves?Is this a poor mans version of a vacuum pump to prevent ring flutter.I would think you would want filtered fresh air being pulled into the base in a street application.:confused:
