My air conditioner has quit all of a sudden, after working fine since it had been converted over to R134a last year. My car is a 1987 Z28 (305TPI). The compressor does not kick in, so I was wondering if it quits when the R134A stuff is low. Does anyone know if this is correct & where should I try to add the stuff ((Which is high pressure end & which low pressure end)).. Thanks
RadarRunner, Take it to a shop and get it checked. It could be as simple as the clutch cycling switch or it could be low on refrigerant. Too many things to list here.
Leo Paugh
MCC #017
www.clark.net/pub/chevelle/mcc.htm
the bitterness of poor quality remains, long after the sweetness of the low price is forgotten
R-134 is also "thinner" than R-12 making it easier to leak out. Often it doesn't leave oil around a spot where it leaks out. Best to leave it to the pros on this one. Not only is can charging dangerous,it is not precise. Even a slight overcharge can make your a/c perform badly. When we recharge a retrofitted system,(after finding and repairing the leak) We use the gauges and system performance to find the ultimate refridgerant charge. Hope this helps-Dan
