1 - 8 of 8 Posts
So I'm trying to get my engine running properly. Its a chevy 350 stock iron block and heads. Its in my 67.
I have an older Holley double pumper 4777-2 Just got rebuilt
Cam specs are DUR @.050 223 ADV DUR 290
Im trying to get my timing and carb adjusted properly. I put a vacuum gauge on my carb and read 11 but was not very steady it would jump around at times. I hunted for a vacuum leak but found none.
i read the timing 101 and got some clarity but really don't know how to start. What do I need to do to find what timing should be set at.
I'm thinking my vacuum advance might not be up for the job but i really don't know. I need some help how to get the basics started.
Thanks !
Check your timing at idle with the vacuum advance hose connected. I bet your timing is going up and down a few degrees.
With 11" of vacuum at idle, your stock vacuum advance will not be fully deployed (it will be "dithering in and out").
Is your distributor a stock "points type" small body ?
If so, try this vacuum can :http://www.autozone.com/autozone/parts/Vacuum-Advance-Distributor/_/N-93xnh?filterByKeyWord=DV+1810&fromString=search&isSearchByPartNumber=true
It will be fully advanced at 8" of vacuum and your timing should be stable.
After that you can set your initial + mechanical to 36*. That's a whole other topic. You will probably have to restrict the mechanical and add some initial.
14-16 initial and 20-22 mechanical is a good starting point.
w/o getting into setting up advance curve - which can be a bit complicated, esp for a novice - I'd set the thing for total timing and see how she runs.
You'll need either a degreed balancer or a timing tape made for the diameter of your balancer.
The old original iron GM heads from the era seem to like ~36* total. So....with your degreed balancer or correctly installed timing tape, disconnect the vac advance hose from the dist and plug the hose with a golf tee or something. Set the park brake, trans in neutral or park, connect your timing light to the #1 plug wire, driver's side front, and start the motor.
Point the light at the timing pointer, paying attention only to "0" if the pointer is also degreed - operating the throttle by hand - bring the RPMs up to 3000 - 3500 and see where the timing is. If you need more to get to 36, rotate the dist CCW. If you're past 36, rotate it CW. Once happy, clamp it down and recheck. Take the RPMs a bit higher to make sure it isn't still advancing. Once you have it set for 36 total and not still advancing, let the motor idle @ about 800 and see where the timing is now. Probably somewhere between 10-16 advanced. Unless you need to mess with the advance curve, this is where you set timing from now on, at idle with VA disconnected and plugged.
It's a bit intimidating setting total timing the first time with your head in there and the motor screaming. Just be sure and keep your fingers and the timing light clear of the fan. Don't wear loose clothing that could get caught in a belt.
I'd expect that cam to have a little more that 11 @ idle, but it also depends on what the idle speed was when checking it. More idle speed = more vacuum. The lumpier the cam as well as the cheaper the vac gauge is can cause an unsteady needle on the vac gauge at idle.
Good luck - we're all counting on you.
My dist is an HEI dist, unknown brand.Would that advance can still be a good idea?
Thank you! I appreciate the help with a starting point!
Great advice.
Might want to have someone in the driver seat do the gas pedal so under the hood you can concentrate on the timing light and dizzy
The DV-1810 can is for a points type distributor.
Here is one that should work for an HEI :
http://www.autozone.com/autozone/parts/Vacuum-Advance-Distributor/_/N-93xnh?filterByKeyWord=DV+1862&fromString=search&isSearchByPartNumber=true
And here is a document covering the different cans available :
http://www.lbfun.com/warehouse/tech_info/timing & vacuum advance/Vaacuum_Advance_Specs.pdf
Discussion Starter #8
UPDATE
Well I got the total timing to 36 and at idle it hits about 13 BTDC. Adjusted by carb and rerouted by vacuum line to the full manifold pressure port on my carb.
Holy crap it runs so damn good now, its reading about 16 on the van gauge, and just purrs at idle. It use to be very choppy at idle and sounded kind of splatty, if that makes sense. I assumed it was my cam. Now its very smooth and much quieter. Almost too quiet, lol. But it idles and runs very smooth, it use to randomly hesitate and pop, now not at all. Thanks for all the help! The amount of knowledge and experience on this forum make trouble shooting so less painful
1 - 8 of 8 Posts
