Ive got a 350 in my 69, Performer RPM manifold, long water pump. The so called Transdapt alt. braket for that application isnt even close, I'm frying alternators at an amazing clip. Ive tryed to modify it, shim it, to no avail. Has this happened to anyone. If so, what was the solution. Thanx in advance. Sean.
Have you checked to see if the alternator is aligned on a vertical plane? If it is not it could be side loading the bearing. Another possibility is to re-install the original (factory) alt. bracket to determine if the problem is even related to the change of brackets. How is the rest of the charging system?
Steve R
Discussion Starter · #3 ·
Thats the problem it not aligned and its because of the upper bracket, unfortunately I dont have the original.
i have been having the same problems with my 81 f-bird, i have been combing the junk yards to find all of my brackets and pullys. so far i only need 1 more (lower power steering bracket) and it should be back to factory. total cost half a day and 20$.
but i had to cut the hole in the alt bracket out to the end with a hacksaw to make it under the bolt. mine lines up real good with the pulleysI did this 3 yrs ago and no alt trouble yet.
