Hi guys,
I have searched the forums for a definitive answer, but just wanted confirmation I have the right of it.
I am considering a wider rear wheel option for my Camaro project. Obviously I understand mini-tubs can provide the clearances I would need to run a 10"+ tyre.
In australia, notching or cutting frame rails is a bit of a "no, no". There are a lot of hoops to jump through, and engineering approvals required, before you can legally drive a vehicle with structural modifications on the road here. Also costs a lot of money to get these approvals.
DSE tubs seem to be the clear choice, but I can see you need to notch the frame a little to install them. ideally I would like to avoid this for the previously mentioned reasons.
I have also seen other comments about people moving the tub back to the rail, gaining some clearances and essentially fabricating a panel to fill the gap. This mod does not cut the frame and provides some extra clearance for a 10" wheel.
Do I have that right???
Can the wheel tub width be increased to accommodate a 10" wheel without messing with the frame?
Says something like that here:
https://www.camaros.net/forums/56-pro-touring/366937-mini-tub-without-cutting-frame.html
For the record I have the Ridetech 4-link installed, so got all that covered from the suspension side of things.
I would be happy enough running a 10" wide that did not rub on anything - that would honestly be plenty for me. I am not greedy with my wheel rubber like some others ; )
What are my options?
Cheers,
Shan
Cheers,
Shan
