First off let me say thanks to everyone for all the help they have provided in the past. It is always great to get counseling and advice from folks that have "already been there and done that". I have a 68 Camaro with a 350 (short water pump), power steering and headers. I am currently using the universal header alternator bracket(s) to hold my stock alternator (external regulator) in place on the driver's side of the car. I am not real happy with the setup because I have tall valve covers that get in the way of adjusting/changing the alternator belt and I can't get the right amount of tension on the belt and as a consequence the belt "sings" to me at higher RPMs. I haven't thrown the belt yet but I'm sure it is just a matter of time. I see MOROSO makes a kit #63825 that will move the alternator to the right side of the block (upper mount) but I don't know if I have to change the pulleys to make it work. Ideally I would like to mount the alternator low on the right side of the motor (haven't seen a manufacturer that makes a low right side bracket set). I can't mount it low on the left side because of the power steering. Does anybody have any thoughts of the best course of action here? Thanks
Scott
Put a long straightedge (yardstick) across the flat portion of the water pump pulley parallel to the belt. I'll bet you'll find your pulleys are out of alignment. On our totally stock '67 the alternator had to be moved 1/4" forward.
Street rod vendors offer many alternator brackets for the sb. Check 'em out.
Scott,
I have a 68 with exactly the same configuration - short water pump, driver's side alt, universal bracket, 1-3/4" headers. I got mine to fit right, but only after a lot of aggravation.
I wound up putting a spacer (I used a nut ground down to the right thickness) on the lower alt bolt in front of the alternator inside the U part of the bracket and slid the bracket as far back as it would go.
I also had trouble getting the lower bracket to bolt real solid to the head - I wound up having to use a stud on the front header bolt. It turned out that my header bolts were too short when going through the alternator bracket AND the header flange. The lower bracket was a little loose and my alternator was vibrating.
Sounds confusing, but the bottom line is that I had to mess with alignment a little to get the belt to run straight and true. I don't know for sure that this is the problem you are experiencing, but it wouldn't hurt to make sure everything bolts in solid and is lined up right.
Good luck
68 Camaro, 383 small block with TH350 trans. 11.98's at 111mph and never trailered.
I had the opposite problem. Used a deep groove alt pulley with stock crank pulley. Had to use a stock one because I needed 3 groove for A/C.
Anyway, I moved the pulley aft as far as I could, and thenI had to grind down the spacer on the alt. shaft to get the belt aligned.
The reason you guys have this problem is because b-4 1969 there were not bolt holes in the cylinder heads. I had a similar problem on my 69 that was converted to this. I've since changed to a Long pump and had a bolt hole drilled and tapped in my head (the cars). Save yourself the big headaches and order the right bracket you need. Check out this link an remember "NO BOLT HOLES IN HEADS",and "SHORT WATERPUMP."
http://www.alangrovecomponents.com/new_page_5.htm
69 Camaro Z28 "clone" - 327 AT
"461" camel back heads,
edelbrock, hooker, ultradyne,
TRW etc.
700R4 TPI transmission
<BLOCKQUOTE>quote:</font><HR>Originally posted by TJS69:
<HR></BLOCKQUOTE>
TJS69, actually none of the brackets I'm using bolt to the front of the head anyway. The bottom bracket bolts to the head using the #1 cylinder exhaust bolts. The top adjustig arm bracket bolts to the water pump bolt.
You are right on about the three bolt holes on the front of the head though.
Eric68- I know that. You have a short water pump to, right ? In 1969 they switched to the long waterpump, put accesory holes in the heads, and switched the alternaor to the passenger side. (A/C to the drivers side).
