1 - 10 of 10 Posts
While planning out my alternator conversion to a CS130 I called the gang at Alan Grove Components to find out if their brackets would work with the new alternator. I was worried about this as the technical reference article notes that you have to modify the brackets for a 68 installation. There answer was 'Yes, just make sure you get an alternator for a 1990 Chevy 1 ton with a 454.' Cool! This alternator has the mounting tabs located at the 6 and 12 o'clock positions just like the current alternator. Needless to say it bolted right up.
Here is the source vehicle:
1990 CHEVROLET TRUCK K3500 1 TON P/U 4WD
8 Cylinders 454 N 7.4L TBI
Duralast part numbers from AutoZone:
DLG1352-6-3 (vs the DLG1345-6-7 in the tech article http://www.camaros.net/techref/ftecref14.html)
I actually got my alternator from O'Reilly Auto Parts as they are much more helpful than my local Autozone. Part number from them was 01-0396.
Hopefully this information will help make the conversion even easier.
Keepin' the archives alive....
Another good 105 Amp CS130 donor vehicle is the 1989 Pontiac Safari Wagon 5.0L. This one saves you the pulley swap as it comes with a v-pulley. 6 and 12 o'clock mounts; bolted right up on the '69. Advance Auto Parts had it for $78 with a $35 core. P/N P79223.
Randy -- awesome info. Frien's alt died today and we were looking for a good number on the CS130.
Timing's everything....
glad to help.
[edit for clarity]
A discussion with a friend reminded me that the alternator I installed (a reman unit) was not threaded for the tension bolt. I was operating under the assumption that it had been stripped and drilled out. I tapped the top hole 3/8NC. Works great, now I can use a 9/16 on the top and bottom bolts. He indicated that many most? of the CS series alternators are made this way. You'll need to put a nut on the back, or tap the hole.
[ 07-26-2004, 08:06 PM: Message edited by: Randy S ]
Just a quick thank you to Randy. Came across this thread when I was searching about a CS alternator conversion. Got the alt for an 89 Safari and the conversion (alt change out and and rewiring) took all of 45 minutes.
This site is the best:thumbsup:
:beers:
Victor
67 vert
W 2LG 3L 4P
I'm going way back and reviving this thread :)
I just picked up the Safari alternator from O'Reillys Part Number: 01-0381
- but where did yall find the pigtail? It doesn't take the normal style two prong plug.
http://www.oreillyauto.com/site/c/detail/ULT0/010381.oap?year=1989&make=Pontiac&model=Safari&vi=1260368&keyword=alternator&partType=01468&parentPartType=C0330
Thanks guys
Here's an old thread with the part numbers and information - http://www.camaros.net/forums/showthread.php?t=130272&highlight=CS130+plug
There are several manufactures, Like Mad Electrical, that make adapter plugs to allow your existing alt. wiring to be plugged into the new CS130 tyoe.
I personnaly like to wire a new connector in so I'm sure the connections are good and there are fewer terminals to go bad...
This all comes at a great time... I'll be upgrading after Christmas :)
For those brousing this info, just beware. The 67 / 68 uses a short water pump with the alternator mounted on the left side of the motor. The 69 uses a long water pump with the alternator mounted on the right side.
Great info....Mine is a LWP/RS mounted (non-factory)
1 - 10 of 10 Posts
