My oil and alternator lights in dash cluster dont turn on when i turn key.I have a center console is this why they dont turn on?Pretty sure they work before cant remember.What to you guys think.
Do you have gauges in the center console?
If you are still using original factory Alternator / Voltage Regulator set-up the GEN light should still self-test as the key turns through the on-start and run positions. Bulb maybe dead?
If you have factory gauges in the console the Oil light should have been converted to be the low FUEL light and the bezel changed to reflect its re-purpose.
It is possible your car was converted after birth to console gauges and the PO didn't bother to replace the bezel.
It's has all factory gauges.I must have did something when i was under the hood.I'm sure it work before.I will have see what i screwed up.Thanks for help.
