AMAZING WEB SITE GUYS! i have a 69 camaro with a rebiult 350 4speed 12bolt rear the problem is i changed the internally regulated alternator with an internally 100amp alternator ive got the correct wire connector for this it has two wires coming out of it and at the rear it has the big 10 gauge hot wire im going to retain the regulator on the rad support and terminate the wires under the tape when i open and clean,fix and sort out everything with the correct gm harness tape does anyone know how to wire this internal regulator to a harness that never had one before your help is greatly appreciated!
