mr STINER I am sure you know the answer to this can you tell if alternator is internal or external by looking at it
Re: alternator
External Reg. terminals look like [ l l ](DN)
Internal Reg. look like [--] (SI) or [----][/(CS)
Re: alternator
John has you covered.
And the internal ones usually ship with a black plastic plug over the field/meter spade hookups.
Re: alternator
so should I eliminate the plug off the harness and hook up the voltage regulator [bypass ] like it shows you how to in the tech section
Re: alternator
You should if going to an internal reg'd alternator.
You can make spaded jumpers and plug into the ext reg connector and not cut off the connector.
Re: alternator
Like this...
