It won't hurt a thing to use a higher amperage alternator. Some reasons alternators have higher outputs these days is due to tighter machining tolerances, improved voltage regulator designs, and better rectifier diodes. Another benefit of newer / higher output alternators is that they have better charging currents at idle. The old sub-50 amp alternators often wouldn't put out enough at idle to keep the battery charged. Consider what kind of loads you expect to put on the alternator and get one that delivers about 2 X the load. Things to consider are head lamps, car stereos, electric fans, etc.
