I got the ambulance ,it run inspite of needing carb.motor sounds solid.
the #'s are :
vin # CCS336B10993(PICK UP CHISSIS)
block = C6B108993
PASS. SIDE HEAD = 338781
has guide plates and screw in studs
option decal in glove box says LF8
breather decal says 91 or better octene recomanded
also has a 400th trans,
and a posi (truck) 1 ton rear(for sale)
would these numbers tell the compression or torque & horse power.
thanks for any info.
drive it like you stole it!!!
67 327 11:1 4spd.
70 454 400thm 10 bolt posi
my camaros
[This message has been edited by 4 speed (edited 11-04-2001).]
Discussion Starter · #3 ·
I double cheched the numbers after I posted the above,I notice the block # was the VIN # that was the only # on the frt pad behind the alt.
also the the only VIN# I could find on the chassis was A plateriveted to the door sill above the latch catch also had some tire psi's on it along with axle weights .
if I can I'll post some pic's
drive it like you stole it!!! :D
67 327 11:1 4spd.
my camaros
Discussion Starter · #5 ·
the ambulance is a 76 ,breather say assembly date is oct 75.
I'll pull the valve cover again and look for thoughs castiing #'s
thanks!
do these look better in the VIN#
CCS336B1089931595
WHAT SITES ARE YOU USING TO GET INFO.?(sorry for hollarin)
67 327 11:1 4spd.
my camaros
[This message has been edited by 4 speed (edited 11-05-2001).]
Discussion Starter · #6 ·
4 speed - those are good heads you've got. Lingenfelter recommends either the 041's or the 781's from the mid 70's because of their better quench area. He claims an additional 10-15 hp over other castings.
You can do lots of things with the heads depending on the intended application. If you're looking to street/strip, then stick some large valves in and find a reputable head porter and finish with a good 3 angle.
Good luck with your rat!
