1 - 10 of 10 Posts
Complete kit including clutch from American Powertrain for 1st generation F-Body Tremec TKO600 5 speed. This is just a file photo I'll try to get some real ones up in the coming days
277172
Asking $4000
TKO 600 GM Street & Strip
26 Spline input shaft
Ratios: 2.87, 1.89, 1.28, 1.1, 0.64
fluid capacity approx 3.2 quarts
Profit TKO installation kit for 67-69 Gen 1 F-Body
AP revolution shifter orginal 4 speed shift position
seamless DOM driveshaft assembly race balanced solid ujoints
driveshaft yoke cryogenically hardened steel
X factor cross member
transmission mount
pilot bearing
reverse light harness
shift knob
console shift pattern plate
Science Friction 11" 26x 1 1/8 organic friction standard clamp load 3 piece clutch up to 400hp/450tq
standard gm mechanical release bearing
ARP pressure plate bolts
10" round stock shift handle for TKO T5
Registering and then immediately offering a $4,000 part with a confusing description and a picture copied from the American Powertrain site isn't a good look. Can you post pictures of the kit as it sits at your place?
Reactions: 130fe
Send us a picture of the kit at your place and put a wrench on top of the trans.
Not to steal the post , but who do you guys buy your TKO or TKX kit from?
Jody's Transmissions, or SST.
Reactions: CantRepeat
Well, he did as y'all asked.👍
Thanks for posting the picture for us. Is it a .64 or .82 fifth gear?
1 - 10 of 10 Posts
