Key off - Full
Key on - 1/2 inch PAST Full
Checked and cleaned the ground to the frame, thats good..
Have power to the sender..
Looked at back of guage. I dont see any wires going to the gauge. Only wires on the whole cluster is the big black plug behind the speedo. Is that correct? Im assuming the fuel gauge works off the circuit panel on the back of the cluster?
Im a body guy, terrible at wiring and do not own an ohm meter. Got a test light though :thumbsup:
What do you guys think is MOST LIKELY the culprit?
Discussion Starter #2
Tonight-
Drained tank completely, gauge read Little more than half
Dropped tank and removed wire, gauge read 3 O'Clock (Way past full)
Thinking it has to be the sending unit.... ?
Was the sending unit... Picked one up at AutoZone, 1 year warranty..
