I posted a topic asking where to buy a adjustable throttle linkage kit and throttle linkage pin's for an edelbrock thunkder series 650. I'm tired of going to the part store not knowing exactly what I'm looking for. Thanks.
The stock throttle rod fits on an edelbrock carb just fine, tho I used a couple of 1/4" washers on the linkage rod to tighten things up a little.
If you want to see what is available, first stop would be Edelbrock.com.
To actually buy it, order from somelace like Jeggs or Summit.
your 78 should have a cable instead of a rod, no???if so, than i think you need an adjustable bracket for the cable...you can get them at autozone or advanced in the mrgasket section for 23.00...the pin you`re lookin for, i found at advanced...summit and jegs will have all of the parts you need, but i`m more of the pay and get right now kinda guy...
