When you hit the turn signal on the wifes 69 RS it will flash approx 15 times and go dead. You can cancel it and and hit it again and the same thing. The brake lights, head lights and tails work fine but the front lights work sometimes.
Can anyone tell me exactly where to locate/check for proper grounds for this problem?
Sounds more like the toe in has been done on a wheell alignment has been done THEN the steering wheel forced onto the column to center it...
The steering wheel needs to be centered, assuming it has been located on the collumn correctly THEN the wheel alignment set.
Covered in detail in a thread in the last couple days
Did not want to start a new post since there seems to be so many on this top. I have replaced the flasher with a 552 replacement, bulbs are all O.K. on four corners but the turn signal does not want to flash. What's going on in my 67 Camaro?
