1 - 2 of 2 Posts
Hi all.
Came up with nothing when I did a search for a procedure to replace the AM Antenna Cable.
I have a 90% complete 67, not disassembled at all.
Anyone out there willing to type up a Step-by-Step for this?
Thank you!
Jasonblu
1) unplug from radio (rear rt side as viewed from inside the car
2) follow cable along lower dash (under glove box) should be 3 or 4 clips to dash lower frame.
3) remove Antenna nut on fender
4) open rt door pull Antenna cable and grommet in 'A' pillar
5) pull Antenna mast and cable up out of fender
6) reverse steps to install
that should get you there :)
1 - 2 of 2 Posts
