What I have always wondered, is are the 2 post so well balanced that you don't have to worry about tipping or swaying, where the anchor bolts need to support the weight without pulling out..
If you read the instructions on a 2 posters, the vechicle HAS TO go on the right way around...we have had several 'accident' in NZ where vechiles wher put on the wrong way and the whole thing has tipped over....
Workshop floors here (building regualtions) require between 5 and 8" of mesh reenforced concret, with compacted dry coarse underneath.
So think about what way you are going to install...drive straight in or reverse in.
Bottom line, it is no big deal to cut a over size hole and dig out extra deep... way over engineer....set the mounting bolts and plate flush when pouring the wheel barrow load of cement...
Then you will NVER have any doubt and piece of mind everytime u use it.
We installed a new 2x poster about 6 months ago in the workshop.
Regardless of the base, the tipping over issues have nothing to do with the foundations...its the geomertry of the arms.
