Hi all, I just finished installing the vacuum canister, actuators and routing all the hoses but headlight doors don't move. I checked, double checked and re-checked the hose routing based on the diagram that came with the new hose kit. I havent seen these in working condition so I am not sure what is supposed to happen (short of the doors opening/closing). Does it take time for a vacuum to build up in the canister the first time? There is a switch(?) on top of the valve (the valve mounted to the vacuum canister where red/green/yellow connect) that can be moved in one direction that says open and the other direction that says normal. Am I correct that it should be at normal? Also, I pulled the hoses off at the light switch (at dash), while engine was running, and don't feel a vacuum on either. Is that normal? I suspect it is something stupid that I am missing. I assumed the hoses were all good, because they are new. But that might not have been a good assumption. I can test them also. Any suggestions?
Thanks,
Mike
Thanks,
Mike
