1 - 2 of 2 Posts
Well, I picked up a big block 69 (thanks Clill!) and I had asked if anyone had a set of headers that fit a big block 69 with p.s.; NOBODY that replied had been able to install them with denting a tube or two. I also posted what Hooker claimed (everyone is using the incorrect mounts and if you have the original style frame mounts that offset the engine to the passenger side and the drivers side is taller to tilt the engine that their headers would fit). So I bought a set of Hooker super-comp 2" headers and believe it or not they actually fit without denting any tubes! I did remove one of the ps cover bolts to remove the washer and let the head of the bolt sit lower but that's it. They are NOT an easy install as you have to pretty much pull the engine out to get them in but they did fit as advertised. I just wanted to pass it along.
Jody
1 - 2 of 2 Posts
