duke,
i'm up in kingman......not quite right around the corner!
if you post what the problem is, there are a ton of people
on this site that could help. supply the basic car info and then specific problem info such as did you just replace the switch or re-wire the whole dash? someone out there probably had the same exact problem as yours and has a quick fix available. if you feel more comfortable you can pm me.
