You can't come up with a true price without knowing the codes on the wheels. FW's look about like YH's and go for half the price. There are other GM as well as reproduction wheels that factor in here. What do you have? With trim rings and center caps? GM or Repro?
They're originals with trim rings and center caps.
Where do I find the code info about the wheels? I can check tomorrow night before I send it off on Saturday to start work on the rear end and suspension.
Thanks!
There should be a 2 letter code and numbers designating month and day on each side of the valve stem hole. Are they 14x7's? 15x7's?
15x7s.
I'll check out the stamping on them Friday. Thanks for everyone's help.
