I was really suprised to find out that these tires have a max pressure of 20lbs. I thought they would be like most passenger tires and 35lbs. I'm not thinking that just because of the shear volume, even 20 is too much. The tire looks quite ballooned. What are you guys running for air pressure??? This is on the back of a '68 SWB. Thanks!
I usually run mine between 11.5 and 12.5 I originally set the pressure by observing the contact patch on the ground. Anything much higher than 12 started "ballooning" the tire as you mentioned, and decreased the footprint patch on the pavement.
I run tubes in mine also.... 31.0 x 18.5 x 15 on 15 x 15 wheels.
