1 - 20 of 22 Posts
Have anyone of you taken a 454 and made it look like an old school 396?
Pictures?
any major changes to do other than valve covers?
If you want to make your car look "slow" put painted valve covers on it. Most people have either chrome or aluminum ones, but I like the orange colored drippers as a no-nonsense approach. Factory pulleys and brackets, too. It fits in the category of "speak softly and carry a big stick."
a 454 already looks exactly like a 396 except for the harmonic balancer- and you gotta know what to look for and look really close to see that. just put all the 396 accessories on it and call it a 396 if anyone asks what it is.
If you want to use a 396 balancer, you can add "heavy metal" to your 454 crank to balance it internally.
I believe the name for this metal is Mallory Metal
ditto what novaderrik said.....
Here is my 454 block with 427 guts. Im going to yank it out in a couple of weeks and stroke it to a 496 and have it still look like this.
I did basically the same as Skip for a friend's '69 SS 396 Chevelle. I used a .030 over 454 which makes 461 cubes. I used the same stock type chrome valve covers and with some double thick gaskets managed to fit a set of roller rocker arms underneath. From the outside it looks like a 375 hp 396. It also has a roller hydraulic cam which sounds a lot like the old solid lifter cam. Unless you start looking closely at the numbers nobody knows the difference.
Skip's Turbo Jet 425 HP sticker is a dead giveaway.;)
Yeah its been about a year now with that sticker and your the second guy that figured it out :thumbsup:. I do it for fun just to screw with people :yes:, you guys know how it is when they say (Nice Mustang). What should i put on there after i build my 496...
About 13" down your top radiator hose, from the thermostat side, I think I see a speck of dust Skip!!!!! :D
That is one nice engine compartment!
Is that an old Performer 2.0??
You got a good eye, that is an old Performer 2.0, are they any good?
The Old Performer 2 will accept either a Spread Bore or Square Barrel Carb. They are great with a 7.5 to 9.5 Static Compression and a Holley Square Barrel Dp with a Torker Cam such as the Crane 266H 10; and I mean torque "Personified". Short shifting at 5000rpm you will be lucky to get it in by 5500rpm. With Headers and a Holley 750Dp your looking at 425Hp and 500ftpds of torque in a Large Oval Port BBC. A hint of LS6 material but not quit there. With a M21 and 4.10's you will exhaust 4th in the 1/4 mile with a top speed of 119 mph; however, that combo will propel 3.08's to 160 mph in 4th shifting the 1/4 out of 3rd at 122 mph.
NOTE: No Intake, Carb or Cam Change except rear ratio - Been there; Done it ;o)
I would say a Performer 2 with Holley and Headers with a crane 266H 10 on a low compression BBC is probably the BEST Bang for the buck.
That's good to hear...
Skeeter, our engine compartments look kind of similar, other than the '68/'69 differences, except yours is much cleaner (and looks MUCH better), and I chose a 427 decal to go on my 454 block with 396/427 guts.
(Can't wait to drive this thing!)
Hey Ron: Long time no hear..... I'm going to pull this motor out in a couple of weeks to get a good look at what exactly the combo in it really is... I'm 99% going to build a 496 stroker and i know the builder will give me a couple different combos, but is that 2.0 intake any good for a 496 and whats a good Comp Cam Hydraulic Roller that wont get swallowed up with the 496. I want a big cam and possibly bigger then what i currently have with my 427 comp cam 280s.... Thanks hope i can get close to 600HP with BBC Oval Port heads and run pump gas.
1 - 20 of 22 Posts
