thats right big performnce. as soon as the sets on the floor are assembled they will be up for grabs. there sbc heads BTW
last pic is a bbc head the first two are sbc's.
BBC heads look at the outline of that port and two 2.02 intake valves
Cool!! they look abit like Jimmy diesel heads. LOL!
Banned
BEAUTIFUL HEADS!!!
It would be way cool if the valves were splayed both ways so they would fit and actuate in a true 4-valve hemi-head chamber and not what I figure is a pent-roof chamber...
But no matter....
pdq67
Check out the web site for these heads!!
http://www.araoengineering.com/dnochrts/dyno_sheets.htm
They post some very very impressive dyno numbers. IT looks like the higher you rev them the more power they make. There never seems to be a decline. Ex 350 with preformer RPM 750 holley and a small hyd roller cam 225* duration and .514 lift made over 668hp @ 7500 rpm and over 500lbs of torque from 3000-7000 rpm. Here is a claim from their website "The unique valve gear arrangement made possible by Arao Performance's patented head design (US Patent #5,007,387) allows rev's to over 9000 RPM without use of exotic valve train parts or freakish valve spring loadings"
9000 Rpm ?? wow !!! you better have a strong bottom end for that!!!
