I am using new ARP harware for my flywheel and clutch. The clutch bolts have a washer with a countersunk bevel on one side. They were loose in the package. Does the chamfer face the pressure plate or bolt head? How's this for trivia!
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
the bevel probably faces the bolt head. look at the bottom of the head of the bolt- i bet it has a little bevel there.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
That's what I thought, too. The bottom of the bolt head has a VERY slightly raised lip that could nestle into the bevel but it wouldn't be full contact. Then only the outer radius of the bolt head would be exerting pressure on the washer.
Rick Dorion
Well, I vote for bevel out facing the under side of the bolt head to prevent stress concentrations where the radius might touch the inner surface of the washer. The bevel prevents the contact and resulting stress concentration.
-Mark.
I just don't understand what purpose the bevel serves. You can see it clearly on their website when you look up the fastener. I'll call them tomorrow.
Rick Dorion
Rick,
Most of ARP's fasteners (and other good fasteners) have a rather large radius where the hed of the bolt meets the shank. If the washer did not have the "bevel" in them, they would not fit flush against the underside of the bolt head. Try it with yours, put the washer on with the bevel away from the bolt head and see if it will fit flush against the bottom of the bolt head. Hold it up to a light to see it good. If the underhead radius is real small, it might not make a difference, but that is the reason for the bevel.
Hope this helps,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1971 Chevelle "Heavy Chevy" original owner
Well, I'm almost blind but I held the bolt before a bright light and there is a slight radius. Thanks. Didn't notice it without looking for it.
Rick Dorion
