1 - 13 of 13 Posts
I'm getting ready to put my motor back together and was curious to see
what you guys where using for your engine lube. I know it seems sorta stupid because yrs ago they didn't have 30 different types of engine lubs, from specific lubes for rings,cylinder walls, to everything else.
I'm looking for a multi purpose lube that will cover it all..:D..No jokes please...My problem is, i'm going to put the bottom end together and it may take a few months before the car is started so i need something that is going to stay in place and not rust my parts out.
Thanks in advance,
Dave
I've been using Lucas semi synthetic assembly lube for a few yrs now on my bikes and car engines...no issues.. Sticks real well..and dilutes into the oil after start up...
Can't say it's the best..but I have never had an issue with it..
There is only one, LUBRIPLATE.
Use regular motor oil on the rings and cylinders.
I use the black stuff. You know, it comes in a grease gun cartridge. It's chassis lube. Molydilidiumsulfide. (sp) It's on every car store shelf. Attributes; water proof, ultra high pressure lube, highest heat resistance (for brake parts) highest shear-protection and it's cheap.
When it first was sold back in the '60's, Isky would double your camshaft warranty if you used it.
I've even used it on a lifter that I accidentally mixed up. Worked fine. The only problem is your new motor oil turns pretty black after it's started.
Banned
GM EOS in a ketchup/mustard squeeze bottle for all, liberal amounts.
One bottle for the whole assembly.
And it's molydisulfide grease.
As Fred suggests, oil needs changing right after break-in.
Discussion Starter · #9 ·
The one issue i'm going to have is that the motor might sit for a month or two
before i get it completly together. I need something that will stick and stay there until
i get it fired up. The GM stuff looking like motor oil and i'm afraid will drain down. The lubriplate looks more like a paste and would stick to the bearings and cam.
Thanks again,
What I like about the lucas assembly lube... Is that is really really sticky...I have used it on a Few shovel heads that sat for a few month before starting...no issues what so ever
I've heard of people using the Lubriplate and waiting a year with no issues. Mine will be about 3-4 months.
Thanks again,
Lubriplate will still be where you put it on 30 years later.
Ever see that whitish blob of grease on a car hinge? That is lubriplate put on when the car was new.
Discussion Starter · #13 ·
So are you guys running the lubriplate on everything or just the bearings? Should i use something different on the cam and rings or just use this stuff for the complete build?
Dave....
1 - 13 of 13 Posts
