Here's the deal:
push horn button and horn stays ON.
dis-connect horn wires at horns
remove horn cap and depress contact on horn contact ring. You can hear the horn relay click on AND off.
However, when you re-connect the horn wires to the horns, the horns are still blasting, albeit intermittently. Take a screwdriver and tap on horn relay and it stops.
So, to me, it sounds like a defective horn relay. But is it? It's brand new. What else can I look for, before I go and buy another relay?
Is there a "leak" on the low-side of the relay (the horn button) that's causing the relay to flutter? I did remove the contact ring completely, so it's not the contact ring.
Sorry for the long post, but I wanted to give all of the details.
thanks - Mark
- horn did not work when I bought car
- replaced steering column (w/ a tilt)
- replaced horn relay
- replaced horn contact ring
thanks - Mark
