when i go to start my camaro, i put my key in the ignition, turn the key and it make that sound like it would when your battery is dead.. but then set up after five sec.. do i have a bad starter?? ignition?? not getting gas in to the engine??
[This message has been edited by Phil G (edited 03-29-2000).]
Maybe your battery is dead. If not check your starter, and or the solonoid. Pretty safe bet it's not fuel system.
Phil first off it is not neccessary that you post the same question over and over and over and over again! once is plenty, Choose the forum that best relates to the problem and please only post the question once.
Did you stop to think that maybe your car won't start because the smell you had from your AC was maybe the wiring burning up. You will have check further to find out what is up. Have you tried to boost the battery what happens, If you want some help you have to give us some info to work with.
