I noticed that the positive post on my battery was black as supposed to silver when I went to start my car today,which in fact did need a trickle and boy was it dead.Could someone tell me what the problem is? or what to look for? All the cables are good,all the conections are tight,and it's a new batt and starter.What's up? Thanx
Steeev:
"Honey,I'm not driving fast.......You want to see fast........
Discussion Starter #2
Anyone at all?
Steeev:
Be sure the connections are clean, and that you altenator is putting out.And it's also possible that you have a weak or bad cell in the battery,and it;s not holding a charge.With the engine off, the battery should show 11-12 volts across the pos+ and neg- posts,with a volt meter.Then with the engine running,check again, and see if you get around 13-14 volts,this would show that the system is chargeing.
Just for the hell of it ,try another battery.Other that that, something may be sucking down the battery,like a light,or cd player o something that is on arter the key is off.
http://www.fototime.com/inv/E695F2E9BD55636
http://hobbystage.net/camaro/tomstv
