I lost the pictures from my last post, so here they are again. I'm trying to find the correct location that this clip mounts to the oil pan bolts. I believe the starter positive wire runs through this. Working on a 68' SS 350 4 speed Convertible. Thanks for all your help! Tom
I can't tell what size bolt hole the clip has but I would install the clip on an oil pan bolt. I installed my cable to the solenoid and then ran it though the frame stand up to the battery. The correct way is using two clips along the edge of the oil pan. The first clip is installed on the third bolt from the front and the other clip is installed on the oil pan between the starter and frame stand.
