On my '68 with power front disc brakes, I have the original style master cylinder with the two bleeder screws on the side of it......It's a new system front to back with either new or rebuilt components including new lines and is completely dry.
So now it's time to fill and bleed the system and the first thing will be to bench bleed the master cylinder and I have the following questions:
1) Can you bench bleed the MC using just the bleeder screws on the side of it or do you bleed it from both the bleeder screws and at the brake line ports also?
2) Should the MC be removed from the car and set level to bleed it or can it be bled in the car in it's natural pointed upwards position? It's in the car now but I'll remove it if I need to.
Thanks......Dave
ps.....can someone tell me about how much brake fluid it should take for the process. I don't want to run out before I'm finished.
Thanks......Dave
