Unless the engine is really hopped up and going to be used at higher rpm, I would say go with the Edelbrock Performer 600cfm. Part number 1406 with electric choke. You could use a holley as well if that is more your flavor.
I have a edlebrock set-up that boodleloof is talking about,(On a 350) works great, good response, and very driveable. It had a holley before and was a little too high-maintence for my tastes. Just bolt it on and start it up...Mike
Id have to agree.
Ive been driving mine for 4 years with no problem. I have a edlebroc carb from summit racing for $100.00.
Never had to adjust or work on it.
Tony
obnoxious 67 camaro under construction. TH350/383 stroker w/ aluminum Edlebroc RPM heads,cam, and carb. Guldstrand mod, Hotchkis 600lbs springs. Next Hotchkis swaybar and disc brakes.This is a "Daily Driver" that still needs A LOT of work.
My friend has the same setup as you and he's running a Holley 650 double pumper mech. 2'nd....the car response real well with that carb.
I have an Edlebrock Performer RPM, with a Holly 750 single; vacuum Secondary, elec choke, Power valve Blowout protection, and clear float window. I got the Carb New, and NEVER had ANY problems, I like it, because you can change jets, and adjust things very easily, without taking the linkage off to take the top half of the carb off like an Edlebrock/Carter.
Very good choice for me. and my throttle response is of a motorcycle. I cant move my foot fast enough.
-67electro
how about a rebuilt boneyard quadrajet? get one off a chevy 350 from the early to mid 70's, and you will be pleased. for the ultimate in no maintainance driving, hook up the factory hot air choke.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
