What is the best flowing sbc head for 1,500 and under?
I'm probably going to get afr's 180-195cc cnc machined heads for a 332" motor and the flow numbers are anywhere from 275-302, I thought that was good for the price but does anyone know of any other brand of alumnium head with higher flow numbers???
AFR's are great heads I've been running them for years. :thumbsup:
i have some protop lines.i heard afr bought them out.any body else heard that?i also heard that afr was owned by comp cams.lotsa exp.there:yes:
AFR's 195 eliminators are near impossible to beet in flow #'s for that size runner. Although that is a little big for you. Your best bet and still great flowing heads are the AFR 180cc SBC Eliminator street cylinder heads.
And yes AFR has a longer lead time because of build to order inventory. about 6-8 weeks on average Figure out what springs you want on the heads first and you can more than likely find a dealer that has them in-stock and can do the spring swap no charge.​
I'd suggest discussing your motor and true needs with Mike Lewis. He's also great to work with and purchase from.
