1 - 8 of 8 Posts
does anybody have any experience with backing up a big block with a ten bolt 8.5 rear end? i currently have the above mentioned rear end and am planning on transplanting a 454 in my camaro. i intend to rebuild the diff and have a posi installed and something around 3.73 gears. I have heard both sides, some say the ten bolt won't last a week others tell me that it would be strong enough for all the power i can build (until I get near 800 ft/lbs). Just looking for some opinions on the matter. thanks
josh
Josh, I've known several people with very healthy engines 400+ hp that ran 8.5 10-bolts with no problems. The 8.2 10-bolt is another story, they will not hold up. There is a story in Feb. Chevy Performance I read last night about this rearend. It goes into alot of detail. Just my opinion. Hope this helps.
Ive done it before, but never ran slicks with it (no traction)..if you plan on hooking the car up I would go with a 12 bolt or 9", but for the street the 8.5 will work.
66/70 chevelle ss396's
69/71 camaros
When everything´s said and done bro..
Look here;
http://home.swipnet.se/mechanixracing
We STILL run a 10 bolt.
However,we also feel we´ve reached the limit now(new motor).
Best ET with the car in Q is 9,92 secs with a 60 of 1,39.
You make the call.
DVC-98.Racing
470 cubes of fogger injected thunder in a 71 z.
[email protected]
Btw.Vehicle weight is approx 3600 punds(1630 kg)
DVC-98.Racing
[email protected]
thanks for all your replies. I had planned on putting a nine bolt in the back but i think with my budget i am going to just rebuilt the 10 bolt it is a 8.5 so i hope it will last a while.
josh
Nice '71 by the way.
Check out the Feb. 2000 issue of Chevy Magazine. There is a great article on 10 bolts and 8.2 vs. 8.5 gears. Good luck
1 - 8 of 8 Posts
