1 - 2 of 2 Posts
Ive got a 68 and at the moment ive got 15x8 rallys all the way around i want to say the tires are 255/60/r15 and the fronts rub real bad turning or when hitting bumps, i thing they might be the wrong backspacing
All i want to know is what is the biggest wheel and tire combo i can fit on all four corners while still being a 15" rally, and where to buy them
Also is it just me or do rallys look really kickass when theyre painted gloss black and the car is black.......
I'm not sure its your wheel as much as it could be your tires. I had 15x8 ralley's on my stock 68 but was running 215/60/r15 and had no problem with rubbing on the front. 15x10 on the rear and when I switched from 235/60/r15 to 225/70/r15 my rubbing problems stopped there. Check your backspacing and your rubbing spots to tell if it is a width or a height problem on your tires and go from there
1 - 2 of 2 Posts
