I have a noise coming from the area of my torque convertor. i thought it was a loose flywheel bolt but all three are tight. it sounds diffrant in every gear. could it be one of the flywheel bolts to the crank. i did the wooden dowel trick to the tranypan and oilpan it didn't sound like it came from there, any ideas, i really would not have to pull engine to check stuff out.
1987 Electric Yellow IROC-Z
350 TPI Tweaked to 420+ hp 366
700R4 with TCI 2500 stall
Richmand 3:73 posi
Richmand 3:73 posi
