1 - 11 of 11 Posts
when ever i go full thottle it feels like it looses power,but when you let up about 1/4 of the thottle it starts to pull harder.
What engine, Carb, etc. do you have?
Maybe the knock detector is picking up a knock. Try some better gas.
David
Check my web page for suspension info:
David's Homepage
67 RS 327
69 Camaro Vintage Racer
When you push the gas pedal to the floor the throttle body will open all the way. This will most certainly "bog" the motor until the engine speed can catch up to the amount of air that is being introduced into the engine. This is normal. Unless you are in first gear or at a high enough RPM in another gear,this will always happen.
I'm already running 93 octane, and its only a stock 305. Somebody told me it might be the throtle position sensor. What do you think? It doesn't matter if i'm at a high RPM or witch gear i'm in ,any other ideas?
[This message has been edited by Timhotrodcam (edited 07-15-2000).]
Have you been given any codes?
Try this link, this guy has some good info!
http://www.mindspring.com/~recaro_ta/proc/tps.htm
67 Camaro LS6 454/TH400/12bolt 3.73
1989 TransAm 5.7L WS6 W/all the options
[This message has been edited by cardude (edited 07-16-2000).]
a faulty t.p.s. could cause ths prob.also
simular problems have been found in the elec.
fuel pumps. if possible install a mech. fuel
pressure gauge and check pressure while this
take place. Good idea to have new fuel filter
installed before you start testing
t.p.s. sensors can malfunction without
setting a code.try testing t.p.s. or
replace. if you need info on how to test
let me know.
1 - 11 of 11 Posts
