1 - 13 of 13 Posts
My Bolt (on one side) of the goose neck for radiator on manifold is not tightening down. What options do I have?
Do I have to replace manifold or is there a way to secure the bolt.
There is a o ring gasket on goose neck that goes over the thermostat
I am posting this under cooling also.
Install a helicoil
Reactions: rp930
or drill out slightly & re-tap for the larger bolt size. You would have to drill out the goose neck also to accommodate the larger bolt size
Given you need to drill and tap for a helicoil....
whatever method takes the least amount of drill size
Both are good ways to save a manifold.
If there's still are a little grip left on those threads, you replace the bolt with a stud, and use some JB Weld to permanently lock it in. (the cheap "sloppy mechanic's" method)
Reactions: Worn Out Welder
You can also wrap some steel wool around the bolt threads. Half A** when a Helicoil is cheap. easy and permanent
I was wondering how long it would take for that response.
Admittedly helicoil would be my choice, but for someone who might be driving a beater & doesn't have many tools or knowledge, (tap & die set, drill bit's helicoil kit). Like I said it's a cheap "sloppy mechanic's" way but one could still get some life out of old tired parts, and way better than steel wool around the bolt threads. LOL
Helicoil. Not that difficult. Permanent.
Reactions: dale68z
Just a heads up it's called a thermostat housing.
Like said above you can helicoil it or drill bigger and tap it.
Helicoil would be my first choice though
Just saying in a pinch it works long enough to get you home or sell the heap. LOL
Reactions: 69Z28
Put the helicoil in drilling it out to the next size 7/16ths it will look like crap how much can they charge for one 3/8ths coil. I used to charge $18 bucks to put one in the more I did the cheaper it got. Its not that hard for that job.Alex
1 - 13 of 13 Posts
