I want to improve my braking by adding a power booster to my setup. Here is a picture of what I have now. I had a local shop put in SSBC front discs + master about 4-5 years ago (stock drums rear). I tend to like the stock setup so I want to go with an 11" booster. I was thinking about this unit from Camaro Central (https://www.camarocentral.com/1967_1969_Camaro_Correct_OE_Style_Disc_Brake_Boo_p/brc-365.htm). This is a GM Restoration Parts unit.
My questions are:
1) It looks like I have a distribution block but I don't see a proportioning valve/pressure regulator (I looked where it should be). Do I need to install a proportioning valve?
2) How is the quality of these GM Resto parts for brakes?
3) Is the metering valve setup preferable over the newer combination valve?
4) Can I reuse the hard lines? They are not that old and it looks like they can be bent to fit the new unit.
Thank you
